[gdal-dev] AREA_OR_POINT vs GDALMD_AREA_OR_POINT
Joaquim Luis jluis at ualg.pt
Thu May 29 14:48:04 PDT 2014
On 29-05-2014 22:08, Even Rouault wrote:
> > Glad to not do, but than I'm left with nothing. If I do instead as
> you say
> > GDALSetMetadataItem(hDstDS, GDALMD_AREA_OR_POINT, "Point", NULL);
> > which than equivalent to
> > GDALSetMetadataItem(hDstDS, "AREA_OR_POINT", "Point", NULL);
> > than, as I showed before and contrary to your python examples, the
> > GDALSetMetadataItem() is not working in our code.
> > > On which dataset do you this : a GTiff dataset ? Opened in update
> mode ?
> > No, not update mode. It's dataset filled an empty MEM. See (lines #167
> > and after)
> http://gmtrac.soest.hawaii.edu/projects/gmt/repository/entry/branches/5.2.0/
> > src/gmt_gdalwrite.c
> Well, I suppose that your local copy of the code use
> GDALMD_ARE_OR_POINT unquoted...
as mentioned before, with and without.
> I've tried a simplified version of your code and it works for me. Do
> you use a recent enough version of GDAL ?
Yes. A svn revision after 1.11.
> Note: for AREA_OR_POINT to be taken into account in GeoTiff, you need
> to define both a geotransform and a SRS.
AHHHHHH. This changes the whole story. Some cases do not set a SRS. Is
there any fall-back SRS that I could use when no info is available to
create one?
Type, 'linear in unknown units'?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140529/752922e1/attachment-0001.html>
