[gdal-dev] AREA_OR_POINT vs GDALMD_AREA_OR_POINT
Joaquim Luis jluis at ualg.pt
Thu May 29 14:58:29 PDT 2014
> > AHHHHHH. This changes the whole story. Some cases do not set a SRS. Is
> > there any fall-back SRS that I could use when no info is available to
> > create one?
> > Type, 'linear in unknown units'?
> I've successfully tried with :
> mem_ds.SetProjection('LOCAL_CS["Unknown"]')
Thanks a lot. I'll work on it.
