[gdal-dev] Error with using GML with Python
Pekka Sarkola pekka.sarkola at gispo.fi
Sun Nov 9 09:28:13 PST 2014
I might have newbie problem with OGR’s GML driver in Python.
I try to read GML files with Python script, but won’t get access to
features. I tried this on Window (ogr version 1.11.1), unfortunately I
couldn’t check this in other enviroments, yet.
So my sample testing script result is
Loop aita layer...
 Count of features: 181
None
None
Start Loop...
End of Loop
And sample script is very simple:
#!/usr/bin/python
# -- Start of test script ---
import sys;
from osgeo import ogr;
driver = ogr.GetDriverByName('GML');
if driver is None:
  print "Error with driver"
  sys.exit(1)
fn = '<your path>/L4131R.xml'
#fn = '/data/nlsfi/MTK-GML/L34131R.xml'
datasrc=driver.Open(fn,0);
if datasrc is None:
  print "Error opening " + fn;
  sys.exit(1);
print "Loop aita layer..."
myLayer=datasrc.GetLayer("Aita")
print " Count of features: "+str(myLayer.GetFeatureCount())
print myLayer.GetNextFeature();
print myLayer.GetFeature(2);
print "Start Loop..."
for feat in myLayer:
  print "a"
print "End of Loop"
# -- End of test script ---
GML file is National Land Survey of Finland's special GML. I can access with
ogrinfo and other command line tools, but not from Python (version 2.7.3).
You can download sample datasets from Kapsi, example
http://kartat.kapsi.fi/files/maastotietokanta/kaikki/etrs89/gml/L4/L41/
Any help is appreciated. I try to check this also in Ubuntu, but currently I
don't have working environment for GDAL 1.11.1. So if somebody can test this
on Ubuntu 14.04 (or any other version above 12.04)
Rgs,
Pekka
Pekka Sarkola
Gispo Oy
pekka.sarkola at gispo.fi   - GSM +358 40 725 2042
www.gispo.fi – www.paikkatieto.com
