[gdal-dev] Implement Mapservers Smooth-SIA algorithm
Even Rouault even.rouault at spatialys.com
Mon Nov 10 02:36:53 PST 2014
teeschke,
> Do you think it's possible to apply the smoothsia-algorithm from mapserver
> to OGR and GDAL tool?
From a very quick look, there's nothing MapServer specific in it. But as
licences of both projects are compatible, an OGR implementation could reuse
MapServer code if practical.
> This algorithm is absolutely missing in the tools
> gdal_contour and ogr2ogr.
> http://mapserver.org/development/rfc/ms-rfc-94.html
I would rather see as an option of ogr2ogr. A -smooth option that would a  -
segmentize "++".
> Because the most of all geodata filetypes don't support curves, the
> smoothed geometries would have more vertices. But I'm sure that the users
> will accept this behavior for the new functionality.
As said above, can be implemented as new optional step.
Even
http://www.spatialys.com
