[gdal-dev] Spatialite and UPDATE triggers
Even Rouault even.rouault at spatialys.com
Mon Nov 10 05:38:28 PST 2014
Le lundi 10 novembre 2014 11:30:32, Even Rouault a écrit :
> Hi Jukka,
> > I noticed that you have worked with INSERT triggers in
> > http://trac.osgeo.org/gdal/changeset/27936.
> Don't mention it to Sandro: he will yell at me for possibly corrupting
> spatialite DBs ;-) I hope that what I've done is safe however, even if
> there's still some slight risk, in case what the triggers do evolve over
> time. Perhaps I should inspect a bit more the definitions of the trigger
> to be sure they are really safe to drop them temporarily.
Strict validation implementation now. Small changes in the trigger definition
will cause the optimization to not drop the trigger. Better be safe than
sorry.
http://www.spatialys.com
