[gdal-dev] Global pass to fix issues related to floating point <--> string conversions sensitive to locale / LC_NUMERIC
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Nov 12 02:08:07 PST 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> Hi,
> Just to notify you that with http://trac.osgeo.org/gdal/ticket/5731 I've done
> a global pass on the whole source tree to hopefully address most issues
> related to floating-point <--> string conversions that were sensitive in a
lot
> of places to the LC_NUMERIC setting, when it was comma instead of point.
Which
> could cause issues when GDAL is integrated into locale-enabled programs like
> QGIS.
Huge work, much appreciated.
-Jukka with Finnish locale
