[gdal-dev] creating graph for single line shape layer using gdal gnm
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Thu Nov 13 00:26:53 PST 2014
Mikhail Gusev <gusevmihs <at> gmail.com> writes:
> Is it correct to do this way?First I will save point layer using
> start and end points of line  layer.Again then connect the two layers
> using autoconnect method . So that I can find shortest path between
> features of the line layer.
> hema,
> yes it's correct, but note, that there must be only one point in a
junction of two line ends in order the connection will be made correct.
You can create such point shapefile from a line shapefile with ogr2ogr by
utilizing Spatialite:
ogr2ogr -f "ESRI Shapefile" nodes.shp lines.shp -dialect sqlite -sql "SELECT
ST_StartPoint(geometry) AS node_geometry FROM lines UNION SELECT
ST_EndPoint(geometry) AS node_geometry FROM lines"
-Jukka Rahkonen-
