[gdal-dev] Interlis driver does not polygonize anymore
Stefan Ziegler stefan.ziegler.de at gmail.com
Fri Nov 14 06:10:10 PST 2014
Hi
I've got some problems with the interlis driver. When I try to convert an
interlis 1 file to shapefiles with the following command:
ogr2ogr shpdir/ 254900/254900.itf,dm01avso24.imd
There are no polygon shapes created. It seems that the point coordinates -
which are stored in two separate columns - are shifted.
Column "Geometrie_" contains a small double value. Column "Geometrie_1"
contains one coordinate. Column "Qualitaet" contains the second coordinate.
Same behaviour with gdal 1.11 and some older master.
regards
Stefan
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141114/fae30e3c/attachment.html>
