[gdal-dev] Aligning Raster Over the Polygon
Simen Langseth simlangen at gmail.com
Tue Nov 18 19:13:33 PST 2014
Is not it possible to do it using gdalwarp?
On Wed, Nov 19, 2014 at 6:45 AM, David Strip <gdal at stripfamily.net> wrote:
>  This is a pretty straightforward task in qgis. Just load the image and
> treat the four corners as ground control points, using the corresponding
> corners of the polygon.
> There's an tutorial here.
> <http://www.digital-geography.com/qgis-tutorial-i-how-to-georeference-a-map/#.VGu9qslNf7U>
> On 11/18/2014 11:29 AM, Simen Langseth wrote:
> Dear GDAL Users:
> I have a raster image which have to be aligned over the polygon.
> Both the raster and polygon have the same coordinate system.
> The figure shows the raster image which has to be fitted over the RED
> polygon.
> https://drive.google.com/file/d/0B2RqG9tSAAIUc3J5ZDN6V01IcG8/view?usp=sharing
> How can I do it guys?
> Thanks.
> Simen
> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141119/ec376551/attachment.html>
