[gdal-dev] gdal_calc.py and NoData issues
Even Rouault even.rouault at spatialys.com
Wed Nov 19 05:21:42 PST 2014
Le mercredi 19 novembre 2014 14:16:05, Andreas Neumann a écrit :
> Hi Even,
> Thank you for trying to help. Unfortunately, the --overwrite option does
> not help.
> I have a very small test file at http://webgis.uster.ch/temp/test.tif
> I used the following options:
> gdal_calc.py -A test.tif --overwrite --outfile=testcalc.tif
> --calc="(A==249)*255+(A<>249)*A"
> All pixels with values of "255" are now "nodata" after running gdal_calc
I wrote "as well", so try with "--overwrite --nodata 99".
> May I please ask you to test/verify this?
> Thanks a lot!
> Andreas
> Am 2014-11-19 13:58, schrieb Even Rouault:
> > Le mercredi 19 novembre 2014 13:49:48, Andreas Neumann a écrit :
> >> Hi,
> >> I have an issue with gdal_calc.py and nodata values.
> >> My input data contains a lot of white pixels. After running
> >> gdal_calc.py
> >> with the following parameters
> >> gdal_calc.py -A test.tif --outfile=testcalc.tif
> >> it turns out that all pixel values with 255 are now nodata values ;-(
> >> Is
> >> there an option so that my 255 values are not turned into nodata? I
> >> tested with the --NoDataValue option (e.g. 99 - which I don't use in
> >> the
> >> image), but it seems to be ignored. For me it is important that black
> >> and white pixels are preserved.
> > Use --overwrite as well, since otherwise the existing output file will
> > be used
> > to be just updated and not recreated.
> > It would be appropriate that the utility warns that --NoDataValue has
> > no effect
> > when the output file exists.
> >> Thanks for any hints,
> >> Andreas
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
