[gdal-dev] SIG Mesh format
Vincent Mora vincent.mora at oslandia.com
Fri Nov 28 01:34:15 PST 2014
I'd like to read/write unstructured mesh informations in a "standard"
sig format: mesh geometry and computation values at nodes, one result
set per computation time step.
Is anyone aware of such a format that would support georeferencing and
whould be a candidate for an ogr driver ?
Thanks,
V.
If this problem rings a bell, read on..
I'm aware of the HDF5 and netcdf, they can be used for unstructured mesh
but gdal-drivers seem to be for raster data only. hdf5 and netcdf are
more "metaformat" and libraries for file io than a file format per-se.
AFAIK:
* there is a lot of standard mesh formats, at least for visualization
there are some that are de-facto standard (.obj, collada...)
* georeferencing in usually not a concern (except openfoam, others ?).
Conceptually, such a format would have:
* a point layer, with a spatial ref sys
* a connectivity table to define the elements (could be associated with
a geometry, but the geometry needs update when points are moved around)
* computation results table(s) for results at points and results at
elements (gauss points)
Postgis topology seems to be close to what I need, butpgdump is not the
easiest data exchange format.
I could use a spatialite database to fit the bill, the good thing with
this approach is to be able to load/edit the point layer with any
standard SIG stuff (qgis, ogr2ogr...). The bad thing is that spatialite
is not the most compact file format known to man. Another bad think is
that I feel like I'm in this case: http://xkcd.com/927/ ... re-inventing
the wheel.
I'll be gratefull for your insight.
