[gdal-dev] LZW Compression on geotiffs
Even Rouault even.rouault at spatialys.com
Wed Oct 1 07:32:03 PDT 2014
Le mercredi 01 octobre 2014 16:26:15, Newcomb, Doug a écrit :
> Well,
> I went back and compiled with 1.11.1 with the external geotiff library and
> got the same result for LZW, tiling made no difference in size .
> As an interesting sideline, I noticed that I had not been compiling with
> LZMA compression  previously and compiled gdal 1.11.1 with LZMA.  I ran:
> gdal_translate -of “GTIFF” -co “COMPRESS=LZMA” on the original file and got
> a file of  149MB in size.
>  I noticed that LZMA compression is not listed as one of the compression
> options for the GeoTIFF format in the online documentation.  Has that
> capability been available long?
GDAL 1.8.0. Should likely be documented. Caution: GeoTIFF LZMA compression is
something that is far from being standard. Probably only GDAL LZMA-enabled
builds with internal libtiff (or with external libtiff 4.0.X built against
liblzma) will be able to deal with that.
If that's an option for you, you could try lossless JPEG2000 compression. See
http://www.gdal.org/frmt_jp2openjpeg.html and the "Lossless compression"
paragraph.
> Doug
> On Wed, Oct 1, 2014 at 9:45 AM, Even Rouault <even.rouault at spatialys.com>
> wrote:
> > Le mercredi 01 octobre 2014 15:41:06, Newcomb, Doug a écrit :
> > > Hi,
> > > I have a 4 band uncompressed geotiff ( NAIP data for North Carolina,
> > > USA) that is 193 MB
> > > I've been going over the compression options for gdal_translate
> > > geotiffs and I note the following:
> > > gdal_translate -of “GTIFF” -co “COMPRESS=PACKBITS” gives me a file that
> > is
> > > 194MB in size
> > > gdal_translate -of “GTIFF” -co “COMPRESS=LZW” gives me a file that is
> > 232MB
> > > in size
> > > gdal_translate -of “GTIFF” -co “COMPRESS=DEFLATE” gives me a file that
> > > is 177MB in size
> > > Of the above  Lossless compression options for geotiff, it seems that
> > > DEFLATE is the only one actually compressing.
> > > I'm running gdal 1.11.0 on Ubuntu 12.04.3 64 bit compiled with
> > ./configure
> > > --with-libz   --with-png  --with-libtiff=internal
> > >  --with-geotiff=internal   --with-jpeg=internal   --with-openjpeg
> > > --with-pg=/usr/local/pgsql/bin/pg_config --with-ogr --with-xerces
> > > --with-geos --with-hdf4 --with-hdf5 --with-poppler=/usr/local/lib
> > > --with-podofo --with-spatialite --with-netcdf
> > > Is this expected behavior?
> > Doug,
> > Not completely surprising that lossless methods don't work well with
> > aerial/satellite imagery.
> > You may also want to test with -co TILED=YES .
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
