[gdal-dev] LZW Compression on geotiffs
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Wed Oct 1 11:02:50 PDT 2014
Even Rouault <even.rouault <at> spatialys.com> writes:
> If that's an option for you, you could try lossless JPEG2000 compression. See
> http://www.gdal.org/frmt_jp2openjpeg.html and the "Lossless compression"
> paragraph.
My numbers for the most simple compressions without tiling:
Original RGB      424 MB
LZW "compressed"  474 MB
Deflate           380 MB
Lossless JP2      197 MB
For comparison:
Tiff as zipped    347 MB
Tiff into png     263 MB
If I have understood right both zip and png are using deflate algorithm so
there might be some place for improving deflate compression in GDAL.
-Jukka Rahkonen-
