[gdal-dev] RuntimeError no COPY in progress
Even Rouault even.rouault at spatialys.com
Thu Oct 2 11:57:53 PDT 2014
Le jeudi 02 octobre 2014 20:50:33, Ari Jolma a écrit :
> On 02.10.2014 20:45, Even Rouault wrote:
> > Le jeudi 02 octobre 2014 18:26:37, Ari Jolma a écrit :
> >> 2014-10-02 19:23:03 EEST ERROR:  COPY from stdin failed: COPY terminated
> >> by new PQexec
> >> Too fast ? lol, no I don't think so. There must be something odd that
> >> happens, wrong escaping, whatever that makes the COPY to fail. Could
> >> you provide some way to reproduce this ?
> That may be difficult.
Could you try changing your code to use another driver to output to another
format, like shapefile, GML, etc... and then try ogr2ogr -f postgresql ?
> I inserted some fprintfs to ogrpgtablelayer.cpp
> and the copy seems ok (and it is ok for the first 500). I even removed
> the only non-geometry field and the situation does not change - the FID
> does not seem to be an issue.
> Then I ran the code until the table is created (this is naturally Perl
> code). Exit, and ran it again now with Layer Open and let the rest run
> as before with insert features. No problem. The problem seems to be when
> inserting into a newly created table.
> Strange.
> Ari
http://www.spatialys.com
