[gdal-dev] 16bit Pixel Arrangement?
    Even Rouault
    even.rouault at spatialys.com
    Fri Oct 10 14:27:41 PDT 2014
On Friday 10 October 2014 01:12:14 M Lewis wrote:
> I am trying to read a NITF image that has a single band with a data type of
> UInt16 and a ColorInterp of 'Undefined' as show below in some details taken
> from the gdalinfo dump:
> NITF_IMODE=B
> NITF_IREP=MONO
> NITF_ISCLAS=U
> NITF_OSTAID=DG
> NITF_PJUST=R
> NITF_PVTYPE=INT
> Corner Coordinates:
> Upper Left  (  774731.700, 2060246.300) ( 72d23'46.92"W, 18d36'54.78"N)
> Lower Left  (  774731.700, 2046011.700) ( 72d23'53.93"W, 18d29'12.10"N)
> Upper Right (  788966.300, 2060246.300) ( 72d15'41.67"W, 18d36'47.89"N)
> Lower Right (  788966.300, 2046011.700) ( 72d15'49.05"W, 18d29' 5.26"N)
> Center      (  781849.000, 2053129.000) ( 72d19'47.89"W, 18d33' 0.05"N)
> Band 1 Block=1024x1024 Type=UInt16, ColorInterp=Undefined
> I am trying to create a corresponding 16bit bitmap for display but having
> trouble as it appears this is a mono image but its coming out 'blue/green'
> so it appears a shift somewhere in the pixel data
Martin,
this does not make sense to me. If it is a single band dataset, the best you
can do is display it in grey levels. You will never have colours from that,
unless you apply some color table with other means.
> Can any one tell me, for a UInt16, what is the likely pixel data arrangement
> that is returned in the RasterIO call as 'Undefined' doesn't help much i.e:
> Is it 5 bits for R, 5 for B etc?
> If it is, is it ABGR or RGBA?
> Or is it none of the above and something else?
That would be extremely odd to pack color components within uint16. Well, I
known this is done in OpenGL textures, but I've never seen that trick in GIS
format ;-)
> Should there be any further clues in the NITF metadata?
> I have looked at the bytes coming back from the RasterIO call and they make
> little sense; all the bottom bits are loaded and the top 5 bits 0 but for a
> mono image I would expect a more even pattern of bits set across all the 16
> bits.
It is very common to have 12 bit imagery. And where each 12 bit sample is
placed in a 16 bit container. Check if there's not a NITF_ABPP metadata item
(ABPP = Actual Bit Per Pixel). That would give you the real dynamics of the
values.
Otherwise just do "gdalinfo -stats the.nitf" and look at the minimum and
maximum values.
You can try the -scale option of gdal_translate to for example convert to 8
bit depth.
> I have simplified the call to RasterIO using the following parameters:
> eBufType = GDT_UInt16
> nBandCount = 1
> pBandMap = NULL   - so it reads just the first band
> nPixelSpace = 0
> nLineSpace = 0
> nBandSpace = 0
> For other things e.g. YCbCR, I understand that RasterIO does some
> translation to RGB, is that what is going on here? If it is, what is the
> translation likely to produce?
In your case, no translation will be done, since there's apparently nothing to
convert.
> QGIS seems to be able to display the image correctly.
As grey level I guess ? And likely after adjusting the min/max values
Best regards,
Even
http://www.spatialys.com
