[gdal-dev] Esri Shapefile: problem with UTF-8 on Windows
Martin Landa landa.martin at gmail.com
Sat Oct 11 09:30:12 PDT 2014
I have problem with converting GML file (UTF-8) to Esri Shapefile on
Windows (Czech version), it fails with error:
Failed to create field name 'NutsLau' : cannot convert to UTF8
I am using configuration option LCO 'ENCODING=UTF8'. Exporting the
same file simply works on my Debian GNU/Linux.
Any idea what could be a problem? Thanks in advance, Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
