[gdal-dev] Esri Shapefile: problem with UTF-8 on Windows
Martin Landa landa.martin at gmail.com
Sat Oct 11 12:38:03 PDT 2014
Hi Even,
2014-10-11 21:31 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> In recent versions of GDAL, this should also recode field names. But I think
> the issue here is just a typo. It should be UTF-8, not UTF8. UTF8 might work
> on Linux since iconv accepts both UTF8 and UTF-8. But on Windows, only UTF-8
> will work.
ah, you are right! Thanks! Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
