[gdal-dev] StringList and Esri Shapefile
Martin Landa landa.martin at gmail.com
Mon Oct 13 01:03:22 PDT 2014
it seems that StringList type is not supported by Esri Shapefile
format. I am not sure how to solve this problem in the right way.
ERROR: Unable to read 20140930_OB_571041_UKSH.xml.gz: Can't create
fields of type StringList on shapefile layers.
Probably the Esri Shapefile driver could convert such data to string
automatically?
Thanks in advance, Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
