[gdal-dev] StringList and Esri Shapefile
Martin Landa landa.martin at gmail.com
Mon Oct 13 03:47:45 PDT 2014
2014-10-13 10:41 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> If you use ogr2ogr, you could use the "-fieldTypeToString StringList" option to
> ask for StringList fields to be converted to String.
ah, ok, I overlooked this option. Is it possible also from Python API?
Thanks, Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
