[gdal-dev] Problems with HDF4
Jonathan Greenberg jgrn at illinois.edu
Wed Oct 15 06:53:55 PDT 2014
Ok, to follow up I got it figured out -- I needed to configure
--enable-shared for HDF4:
./configure --disable-fortran --disable-netcdf --enable-shared
It turns out I have another piece of software that required the HDF4
fortran libraries (which can't exist along with a shared library
install), so the two conflict with one another.  I'll install two
versions moving forward, unless someone has a better solution!
Reference: http://www.hdfgroup.org/HDF-FAQ.html#11share
--j
On Tue, Oct 14, 2014 at 1:12 PM, Jonathan Greenberg <jgrn at illinois.edu> wrote:
> Gdallers:
> I'm having some issues with a source-built GDAL's support of HDF4 on a
> Linux box.  I've repeated this with both GDAL 1.10.1 and 1.11.1.  The
> HDF is a landsat HDF:
> @server> gdalinfo "/pathro/lndsr.LT51950531990333ESA00.hdf"
> ERROR 4: Failed to open HDF4 file
> "/pathto/lndsr.LT51950531990333ESA00.hdf" for SDS reading.
> gdalinfo failed - unable to open '/pathto/lndsr.LT51950531990333ESA00.hdf'.
> What is weird is that the install of both HDF4 and GDAL appeared to
> work correctly.  Certainly gdalinfo --formats lists HDF4 as one of the
> working formats.  The configure script I used for HDF4 was:
> ./configure --prefix=/usr/apps/oa --with-pic
> --with-jpeg=/usr/apps/oa/lib --with-zlib=/usr/apps/oa/lib
> And for GDAL:
> ./configure --prefix=/usr/apps/oa/ --with-python --without-sqlite3
> Any ideas?
> --j
> Jonathan A. Greenberg, PhD
> Assistant Professor
> Global Environmental Analysis and Remote Sensing (GEARS) Laboratory
> Department of Geography and Geographic Information Science
> University of Illinois at Urbana-Champaign
> 259 Computing Applications Building, MC-150
> 605 East Springfield Avenue
> Champaign, IL  61820-6371
> Phone: 217-300-1924
> http://www.geog.illinois.edu/~jgrn/
> AIM: jgrn307, MSN: jgrn307 at hotmail.com, Gchat: jgrn307, Skype: jgrn3007
Assistant Professor
Phone: 217-300-1924
