[gdal-dev] reading arbitrary raster into rgb
Michael Katz - NOAA Affiliate michael.katz at noaa.gov
Fri Oct 17 15:31:16 PDT 2014
(I apologize if this is a repost. I signed up the for the list yesterday
and it appeared the first attempt to post was rejected, but I don't know
how to be sure.)
I am using GDAL through the C++ api.
I want to be able to read an arbitrary raster file (in particular I'm
interested in (geo)tiff files and jpeg2000 files) into an RGB buffer, where
each value is a byte.
I was hoping to see an API like dataset->GetRasterRectToBuffer() that would
operate on the image level (not the band level) and would let me specify
that my buffer was an RGB byte buffer, and the library would do all the
right conversions, regardless of the data type and number of bands of the
source file. For instance, the source file could have CMYK bands with float
values, and it would still extract correctly to my RGB buffer.
Looking at: http://www.gdal.org/gdal_tutorial.html
I'm told that the main API to use to read data in GDAL is RasterIO().
But I'm scared by RasterIO() because it operates on a band. So that means I
already have to do my own logic to determine the number of bands in the
source file and map them to bands in my output RBG file. That seems
complicated in the general case. It seems like handling all the
possibilities of RGB, BGR, CMYK, HSL, etc. is exactly the kind of thing a
data abstraction raster library could save you from having to worry about.
As I say, I was hoping to find an API that operated at the whole image
level, not the band level, and could do whatever is best to get an RGB
image from whatever source. Maybe if it's not part of the GDAL library
still someone has put together some code to handle arbitrary source image
to RBG image mapping?
A lesser question is that I'm confused about the design of RasterIO()
itself. I see from its API description that it does a lot of nice
conversion as needed:
This method allows reading a region of a GDALRasterBand
<http://www.gdal.org/classGDALRasterBand.html> into a buffer, or writing
data from a buffer into a region of a GDALRasterBand
<http://www.gdal.org/classGDALRasterBand.html>. It automatically takes care
of data type translation if the data type (eBufType) of the buffer is
different than that of the GDALRasterBand
<http://www.gdal.org/classGDALRasterBand.html>. The method also takes care
of image decimation / replication if the buffer size (nBufXSize x
nBufYSize) is different than the size of the region being accessed (nXSize
x nYSize).
But then reading the intro tutorial (http://www.gdal.org/gdal_tutorial.html)
I see:
The pData is the memory buffer the data is read into, or written from. It's
real type must be whatever is passed as eBufType, such as GDT_Float32, or
GDT_Byte. The RasterIO() call will take care of converting between the
buffer's data type and the data type of the band. Note that when converting
floating point data to integer RasterIO() rounds down, and when converting
source values outside the legal range of the output the nearest legal value
is used. This implies, for instance, that 16bit data read into a GDT_Byte
buffer will map all values greater than 255 to 255, *the data is not
scaled!*
Not scaling seems really strange to me, and seems to make RasterIO() much
less useful. It seems like if I want to get byte values out, I'll need to
have code that checks the source data type, then allocates a buffer of that
GDALDataType's size, then does the read, then goes through and
copies-and-scales each value into my destination RGB buffer, with a
different case for handling each GDALDataType. I'm just wondering, since
RasterIO() "automatically takes care of data type translation", why it
would pin (i.e., destroy) all the data, instead of scaling it. Are 16 bit
values pinned to byte values (as in the example the tutorial cites) useful
to anyone?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141017/8b7c41b9/attachment.html>
