[gdal-dev] Handle Spaces in Rasterlite Database Path
Jema jemabingham at gmail.com
Tue Oct 21 14:51:39 PDT 2014
OS:  Windows 7, 64-bit
GDAL:  1.11.0, 32-bit, C# Bindings
I successfully created a rasterlite database and added multiple rasters in
a directory path without spaces.  The database file was then moved into a
directory with spaces, and now I'm unable to connect to it.
Using the connection string syntax
(RASTERLITE:rasterlitedb_name[,table=raster_table_prefix];
http://gdal.org/frmt_rasterlite.html), I've tried without luck to isolate
the rasterlitedb_name containing spaces with any form of delimiter that I
could think of.  As I won't be able to control the final storage location
of the database, any advice would be appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Handle-Spaces-in-Rasterlite-Database-Path-tp5168772.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141021/78ce0368/attachment.html>
