[gdal-dev] Handle Spaces in Rasterlite Database Path
Even Rouault even.rouault at spatialys.com
Tue Oct 21 15:38:10 PDT 2014
Le mardi 21 octobre 2014 23:51:39, Jema a écrit :
> OS:  Windows 7, 64-bit
> GDAL:  1.11.0, 32-bit, C# Bindings
> I successfully created a rasterlite database and added multiple rasters in
> a directory path without spaces.  The database file was then moved into a
> directory with spaces, and now I'm unable to connect to it.
> Using the connection string syntax
> (RASTERLITE:rasterlitedb_name[,table=raster_table_prefix];
> http://gdal.org/frmt_rasterlite.html), I've tried without luck to isolate
> the rasterlitedb_name containing spaces with any form of delimiter that I
> could think of.  As I won't be able to control the final storage location
> of the database, any advice would be appreciated.
Jema,
Spaces in filenames were not possible up to the fix I've just pushed in trunk
Even
http://www.spatialys.com
