[gdal-dev] gdalwarp giving two different results with the same input
    VILLARD, Pierre
    pierre.villard at capgemini.com
    Fri Oct 24 00:35:30 PDT 2014
I am using GDAL (GDAL 1.9.2, released 2012/10/08) to change of EPSG referential on a GeoTiff file. I do the exact same command on two different computers (with the same version of GDAL and tiff libraries). And I get two different results... I am out of options, any idea ? Any place I should have a look ?
Command :
gdalwarp -s_srs EPSG:3975 -t_srs EPSG:4326 input.tif output.tif
Input file :
Driver: GTiff/GeoTIFF
Files: input.tif
Size is 1388, 584
Coordinate System is `'
Origin = (-17321655.543400000780821,7332251.365589999593794)
Pixel Size = (24959.157843515851710,-25110.449882157532556)
Metadata:
lat#_FillValue=9.96921e+36
lat#long_name=latitude
lat#units=degrees_north
lon#_FillValue=9.96921e+36
lon#long_name=longitude
lon#units=degrees_east
NC_GLOBAL#conventions=CF-1.4
NC_GLOBAL#creation_date=2014-10-20T16:12:01
NC_GLOBAL#datum=+ellps = WGS84
NC_GLOBAL#ease_global=yes
NC_GLOBAL#ease_origin_lat=-83.517136
NC_GLOBAL#ease_origin_lon=-179.87032
NC_GLOBAL#ease_projection=cylindrical
NC_GLOBAL#ease_resolution=25
NC_GLOBAL#grip_mapping=projection
NC_GLOBAL#history=none
NC_GLOBAL#institution=SMOS CATDS Processing Chain
NC_GLOBAL#netcdf_version_id=3.6.2
NC_GLOBAL#product_version=1.0
NC_GLOBAL#proj4text=+proj=cea +lon_0=0 +lat_ts=30 +x_0=0 +y_0=0 +ellps=WGS84 +units=m +no_defs
NC_GLOBAL#srid=EPSG:3975
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-17321655.543, 7332251.366)
Lower Left  (-17321655.543,-7332251.366)
Upper Right (17321655.543, 7332251.366)
Lower Right (17321655.543,-7332251.366)
Center      (   0.0000000,   0.0000000)
Band 1 Block=1388x1 Type=Float64, ColorInterp=Gray
On computer A (the result I am expecting) :
Files: output.tif
Size is 1355, 657
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (-179.524544819822239,87.025797325816669)
Pixel Size = (0.264973369536817,-0.264973369536817)
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-179.5245448,  87.0257973) (179d31'28.36"W, 87d 1'32.87"N)
Lower Left  (-179.5245448, -87.0617065) (179d31'28.36"W, 87d 3'42.14"S)
Upper Right ( 179.5143709,  87.0257973) (179d30'51.74"E, 87d 1'32.87"N)
Lower Right ( 179.5143709, -87.0617065) (179d30'51.74"E, 87d 3'42.14"S)
Center      (  -0.0050870,  -0.0179546) (  0d 0'18.31"W,  0d 1' 4.64"S)
Band 1 Block=1355x1 Type=Float64, ColorInterp=Gray
On computer B :
Files: output.tif
Size is 1358, 651
GEOGCS["WGS 84",
    DATUM["WGS_1984",
Origin = (-179.674959335984454,86.219877359659435)
Pixel Size = (0.264688310439600,-0.264688310439600)
Metadata:
  AREA_OR_POINT=Area
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  (-179.6749593,  86.2198774) (179d40'29.85"W, 86d13'11.56"N)
Lower Left  (-179.6749593, -86.0922127) (179d40'29.85"W, 86d 5'31.97"S)
Upper Right ( 179.7717662,  86.2198774) (179d46'18.36"E, 86d13'11.56"N)
Lower Right ( 179.7717662, -86.0922127) (179d46'18.36"E, 86d 5'31.97"S)
Center      (   0.0484035,   0.0638323) (  0d 2'54.25"E,  0d 3'49.80"N)
Band 1 Block=1358x1 Type=Float64, ColorInterp=Gray
Thanks for your help !
Regards,
Pierre.
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
