[gdal-dev] Create PostGIS database using OGR/GDAL
Even Rouault even.rouault at spatialys.com
Fri Oct 24 01:19:22 PDT 2014
Le vendredi 24 octobre 2014 09:45:03, Paul Meems a écrit :
> Thanks for your reply.
> MapWinGIS is indeed a Windows-only project written in C++.
> My test application is written in C#, so I can use npsql to connect to
> PostGIS and send the 'Create database' statement.
> But I'm mostly wondering why I can do everything with the PostGIS driver,
> except create or drop a database.
> Perhaps the driver needs a ExecuteNonQuery() function, like npsql does?
Paul,
Up to know ExecuteSQL() ran passed SQL inside a transaction except when it was
a VACUUM that requires NOT to be run inside any transaction. Apparently CREATE
DATABASE too. I've reverted the logic (in trunk): now  passed SQL is always
run outside of transaction except in the case of SELECT ... FROM .... where we
actually create a cursor to scroll the results, which require a transaction.
So now I can run CREATE DATABASE
Even
http://www.spatialys.com
