[gdal-dev] Transform pixel coordinates
Artur Bercik vbubbly21 at gmail.com
Sat Oct 25 00:29:13 PDT 2014
On Sat, Oct 25, 2014 at 4:09 PM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 25.10.2014 um 07:05 schrieb Artur Bercik:
>> On Sat, Oct 25, 2014 at 2:00 PM, Andre Joost <andre+joost at nurfuerspam.de>
>> wrote:
>>  Am 25.10.2014 um 06:03 schrieb Artur Bercik:
>>>  Dear GDAL users
>>>> I have a raster image of 406 lines and 270 samples with 5km pixel size.
>>>> The
>>>> center coordinates (lats and lons in degrees in GCS) of upper left
>>>> pixel,
>>>> and the center coordinates (lats and lons in degrees in GCS) of the
>>>> lower
>>>> right pixel  are given, how can I calculate the coordinates of upper
>>>> left
>>>> corner (ulx and uly) and the coordinates of lower right corner (lrx and
>>>> lry)?
>>>>  You need to know the projection definition to calculate from distance
>>> in
>>> pixel or km to degrees.
>> yes the projection are in GCS with WGS84 datum
> GCS has units of degrees, not kilometers. Your image is 2030x1350 km, but
> you have to know if it is Mercator, Transverse Mercator, Lambert Coformal
> Conical, Stereographic, Albers Equal Area, Sinusoidal or whatever. And you
> have to know the origin of the projection, like Central meridian of UTM
> projections. And if North is upwards or not.
> sorry, yes the pixel size are in degrees,0.047 deg.(5 km approx. at
equator), in GCS and WGS84.
> Greetings,
> André Joost
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20141025/0e4eeff2/attachment.html>
