[gdal-dev] Re-projecting with valid geometry
klo uo klonuo at gmail.com
Sat Sep 6 05:13:05 PDT 2014
I have PostGIS table with multipolygon geometry column of ~2000 features
with valid geometries. Most are single polygons.
These were originally in 900914 projection.
I tried to re-project to 4326, first with org2ogr then with PostGIS's
ST_Transform() function.
In both cases I get results with couple of invalid geometries in a manner
of:
  segment [#] of ring [#] of polygon [#] intersects segment [#] of ring [#]
of polygon [#] at [x], [y]
reported by QGIS "Check geometry validy" function, or same as a result from
PostGIS's ST_IsValid() function.
Interestingly table reprojected with ogr2ogr shows errors on different
features then errors generated by PostGIS's ST_Transform() function.
I wonder if there are some steps I can take before re-projecting or
afterward, that will produce valid transformation, without need of
correcting erroneous geometries by hand after re-projecting data?
Thanks
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140906/0996896e/attachment.html>
