[gdal-dev] GetFeatureCount() bForce set to FALSE
    Martin Landa
    landa.martin at gmail.com
    Mon Sep  8 23:15:07 PDT 2014
2014-09-09 4:54 GMT+02:00 David Strip <gdal at stripfamily.net>:
> 83     int                  GetFeatureCount(int = TRUE);
> ie, you have not changed the default to FALSE as you intended. If this is the code you're compiling, it would certainly explain your problem.
no, of course I changed the code, ie.
int                  GetFeatureCount(int = FALSE);
locally. I agree that it's a bad practice and I solved the problem
based on Even's suggestion. Martin
Martin Landa * http://geo.fsv.cvut.cz/gwiki/Landa
