[gdal-dev] unable to write a shapefile using ogr
Kyle Shannon kyle at pobox.com
Wed Sep 10 08:37:18 PDT 2014
Beau,
On Wed, Sep 10, 2014 at 7:30 AM, Beau Taylor <purelyamethyst at gmail.com> wrote:
> The following program successfully creates a shape file I am requiring.
> from osgeo import ogr
> from osgeo import osr
> def myRing(coords):
>     ring = ogr.Geometry(ogr.wkbLinearRing)
>     for xy in coords:
>         ring.AddPoint(xy[0],xy[1])
>     return ring
> coords = [(-23.378906,68.974164), (-23.378906,34.307144),
> (31.464844,34.307144), (31.464844,68.974164), (-23.378906,68.974164)]
> ring = myRing(coords)
> poly = ogr.Geometry(ogr.wkbPolygon)
> poly.AddGeometry(ring)
> outDriver = ogr.GetDriverByName('ESRI Shapefile')
> data_source = outDriver.CreateDataSource('test.shp')
> srs = osr.SpatialReference()
> srs.ImportFromEPSG(4326)
> layer = data_source.CreateLayer('test.shp', srs, ogr.wkbPolygon)
> feature = ogr.Feature(layer.GetLayerDefn())
> feature.SetGeometry(poly)
> layer.CreateFeature(feature)
> feature.Destroy
> data_source.Destroy()
> However, I did not know how to do the followings:
> -set the color of outer ring as blue,
> -do not fill the polygen
Style is usually dictated by the application.  You can set them in the
app, or for some formats/drivers you can use the OGR style API:
http://gdal.org/ogr_feature_style.html
AFAIK, shapefiles do not support styles
> -name the feature as 'test'
Add a field to the feature definition, called 'name', see the
tutorial, I think it has that exact example:
http://gdal.org/ogr_apitut.html
> I hope someone can help me.
> Thanks in the advance.
> Beau
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
If you are using GDAL/OGR 1.x, use the docs at:
http://gdal.org/1.11/index.html
Kyle
