[gdal-dev] S57 and area reconstruction
vwf vwf at vulkor.net
Wed Sep 10 22:33:50 PDT 2014
Hello,
My question is about S57, not gdal, but one of you may be able to help
me.
When an area (like "prcare") is at the edge of a cell (map) there will
be a vertex on the edge of the cel. With several cells the full area can
have several lines going through the area. Is there a trick/technique to
reconstruct the outer edge or remove the extra lines?
Thank you,
Frits
