[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to transform, unable to compute output bounds.
Love ljvillarin30 at gmail.com
Thu Sep 11 01:45:31 PDT 2014
I know I'm not the first to post this topic and encountered this problem.
But I've search and read some posts related to this and tried their
solutions but no luck. I really can't figure out what is causing this
problem. How am I going to solve it? Badly need help!
I have tried gdalwarp -wo SOURCE_EXTRA=100 -wo SAMPLE_GRID=YES and still no
luck.
Here are the info:
gdalwarp -t_srs "+proj=longlat +datum=WGS84"
HDF4_SDS:UNKNOWN:"A2014042042000.L2_LAC.SeAHABS.hdf":37 hdf.tif
Creating output file that is 783P x 697L.
Processing input file
HDF4_SDS:UNKNOWN:A2014042042000.L2_LAC.SeAHABS.hdf:37.
Warning 1: Unable to compute source region for output window 0,0,783,697,
skipping.
0...10...20...30...40...50...60...70...80...90...100 - done.
*GDALINFO:*
Driver: HDF4Image/HDF4 Dataset
Files: A2014042042000.L2_LAC.SeAHABS.hdf
Size is 563, 880
Coordinate System is `'
Metadata:
  bad_value_scaled=-32767
  bad_value_unscaled=-32767
  Calibration Data=A2014042042000.L1A_LAC.eAHAB.hdf,
MYD02_Reflective_LUTs.V6.1.17.19_OC.hdf, MYD02_Emissive_LUTs.V6.1.1
7.19_OC.hdf, MYD02_QA_LUTs.V6.1.17.19_OC.hdf
  cdm_data_type=swath
  Conventions=CF-1.6
  creator email=data at oceancolor.gsfc.nasa.gov
  creator name=NASA/GSFC/OBPG
  creator url=http://oceandata.sci.gsfc.nasa.gov
  date_created=20140211T064516Z
  Day or Night=Day
  Earth-Sun Distance Correction=1.02664971351624
  Easternmost Longitude=136.7005615
  End Center Latitude=11.01664448
  End Center Longitude=131.961853
  End Day=42
  End Millisec=15905744
  End Node=Ascending
  End Time=2014042042505744
  End Year=2014
  Flag Percentages=0, 1.770345688, 0, 52.53552246, 57.10398483, 8.07766819,
0.434966892, 0, 29.46895599, 64.5276947, 0.0
002018407686, 0.4016631842, 0, 0, 2.331059217, 0.0367350243, 0, 0, 0,
0.4466736615, 77.9515152, 0, 1.508356214, 0, 0, 1.
087921858, 0, 72.44247437, 1.770345688, 6.767116547, 90.6432724, 0
  geospatial_lat_max=11.47631836
  geospatial_lat_min=2.273697615
  geospatial_lat_units=degrees_north
  geospatial_lon_max=136.7005615
  geospatial_lon_min=125.5854034
  geospatial_lon_units=degrees_east
  Latitude Units=degrees North
  license=
http://science.nasa.gov/earth-science/earth-science-data/data-information-policy/
  long_name=Chlorophyll Concentration, OC3 Algorithm
  Longitude Units=degrees East
  Lower Left Latitude=11.47631836
  Lower Left Longitude=135.0154266
  Lower Right Latitude=9.963588715
  Lower Right Longitude=125.5854034
  Mask Names=ATMFAIL,LAND,CLDICE,HILT
  naming_authority=gov.nasa.gsfc.sci.oceandata
  Node Crossing Time=0000334000000
  Northernmost Latitude=11.47631836
  Number of Bands=16
  Number of Pixel Control Points=563
  Number of Scan Control Points=880
  Number of Scan Lines=880
  Orbit Node Longitude=-999
  Orbit Number=-1
  Pixels per Scan Line=563
  Scene Center Latitude=7.185176849
  Scene Center Longitude=132.8315887
  Scene Center Scan Line=440
  Scene Center Solar Zenith=26.09000015
  Scene Center Time=2014042042403706
  Sensor Name=HMODISA
  Upper Left Latitude=3.718107462
  Upper Left Longitude=136.7005615
  Upper Right Latitude=2.273697615
  Upper Right Longitude=127.4018173
  Westernmost Longitude=125.5854034
Geolocation:
  LINE_OFFSET=0
  LINE_STEP=1
  PIXEL_OFFSET=0
  PIXEL_STEP=1
  SRS=GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0
,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHOR
ITY["EPSG","9108"]],AUTHORITY["EPSG","4326"]]
  X_BAND=1
  X_DATASET=HDF4_SDS:UNKNOWN:"A2014042042000.L2_LAC.SeAHABS.hdf":11
  Y_BAND=1
  Y_DATASET=HDF4_SDS:UNKNOWN:"A2014042042000.L2_LAC.SeAHABS.hdf":12
Corner Coordinates:
Upper Left  (    0.0,    0.0)
Lower Left  (    0.0,  880.0)
Upper Right (  563.0,    0.0)
Lower Right (  563.0,  880.0)
Center      (  281.5,  440.0)
Band 1 Block=563x880 Type=Float32, ColorInterp=Gray
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140911/ef8c07c7/attachment-0001.html>
