[gdal-dev] gdal_translate ERROR 1: nc_put_vara_double(IMAGE.grd): NetCDF: Start+count exceeds dimension bound
Joaquim Luis jluis at ualg.pt
Fri Sep 12 06:08:25 PDT 2014
Sebastian,
Any particular reason why you would want to use that so old and abandoned
format (-of GMT)? Do not confuse it with the netCDF CF that GMT uses since
GMT 4.0 (released many years ago). Note also that in GMT5 you can use the
GeoTiff directly, or convert it with grdreformat or with gdal_translate
but to netCDF (not to 'GMT')
Joaquim
> Hello,
> I have a problem with the following GeoTIFF:
> gdalinfo IMAGE.tif
> Driver: GTiff/GeoTIFF
> Files: IMAGEDATA/IMAGE.tif
> Size is 46800, 55200
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 30S",
>      GEOGCS["WGS 84",
>          DATUM["WGS_1984",
>              SPHEROID["WGS 84",6378137,298.257223563,
>                  AUTHORITY["EPSG","7030"]],
>              AUTHORITY["EPSG","6326"]],
>          PRIMEM["Greenwich",0],
>          UNIT["degree",0.0174532925199433],
>          AUTHORITY["EPSG","4326"]],
>      PROJECTION["Transverse_Mercator"],
>      PARAMETER["latitude_of_origin",0],
>      PARAMETER["central_meridian",-3],
>      PARAMETER["scale_factor",0.9996],
>      PARAMETER["false_easting",500000],
>      PARAMETER["false_northing",10000000],
>      UNIT["metre",1,
>          AUTHORITY["EPSG","9001"]],
>      AUTHORITY["EPSG","32730"]]
> Origin = (422999.375000000000000,2201000.625000000000000)
> Pixel Size = (1.250000000000000,-1.250000000000000)
> Metadata:
>    AREA_OR_POINT=Point
> Image Structure Metadata:
>    COMPRESSION=PACKBITS
>    INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  422999.375, 2201000.625) (  5d 2'44.07"W, 70d17' 7.59"S)
> Lower Left  (  422999.375, 2132000.625) (  5d 6'33.10"W, 70d54'13.43"S)
> Upper Right (  481499.375, 2201000.625) (  3d29'30.00"W, 70d17'46.95"S)
> Lower Right (  481499.375, 2132000.625) (  3d30'25.10"W, 70d54'54.17"S)
> Center      (  452249.375, 2166500.625) (  4d17'17.74"W, 70d36' 6.69"S)
> Band 1 Block=46800x1 Type=UInt16, ColorInterp=Gray
> I want to translate it into a GMT grid file using gdal_translate:
> gdal_translate -of GMT IMAGE.tif IMAGE.grd
> But this produces an error and the file is not useable afterwards.
> dimension bound
> gdalinfo  IMAGE.grd
> Warning 1: IMAGE.grd is a netCDF file, but not in GMT configuration.
> gdalinfo failed - unable to open 'IMAGE.grd'.
> Can anybody explain this and offer a solution?
> Thanks in advance!
> Sebastian.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
