[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to transform, unable to compute output bounds.
Andre Joost andre+joost at nurfuerspam.de
Fri Sep 12 09:10:22 PDT 2014
Am 12.09.2014 04:54, schrieb Love:
> Hi,
> The gdalinfo in my post is the gdalinfo of the subdataset 37. I have also
> tried gdal_translate but when I tried to use gdalwarp using the
> gdal_translate output, it has error. I really need to use gdalwarp so that
> I could project the image into epsg:4326(+prj=longlat). If I'm going to use
> the gdal_translate I am ask to indicate the gcp which is not good in my
> case because I have many hdf files in my local directory and maybe they
> have different gcp and I need to batch process them later using the
> gdalwarp with the +proj=longlat command. What could be the solution?
gdalwarp needs the -geoloc switch, and the target extent with -te. See
also
<http://osgeo-org.1560.x6.nabble.com/gdal-dev-Geolocation-Arrays-td4372909.html>
There does not seen to be any progress on this issue.
The values for -te can be found with gdalinfo on the subdataset.
HTH,
André Joost
