[gdal-dev] Fwd: ogr2ogr. SQL seems to disable use_gpx_extensions
Even Rouault even.rouault at spatialys.com
Fri Sep 12 11:53:04 PDT 2014
Le vendredi 12 septembre 2014 20:35:34, Pedro Machado Monteiro a écrit :
> Thank you very much, Even.
> By the way, unlike the alias for the tag <*cmt*>, the alias for the tag <
> *desc*> gave me a syntax error in the SQL:
Yes, DESC is a SQL reserved keyword to ask for descending sorting order. When
you want to use it as an identifier, it must be quoted, e.g. with single quote
character
 "SELECT Linha AS name , IDENTIFICA AS 'cmt' FROM FaunaPnpg_wgs84_teste_utf8"
http://www.spatialys.com
