[gdal-dev] Extract subdataset from netCDF in a given directory
Andre Joost andre+joost at nurfuerspam.de
Fri Sep 12 23:32:45 PDT 2014
Am 11.09.2014 16:58, schrieb Andre Joost:
> According to http://www.gdal.org/frmt_hdf5.html, the syntax should be:
> HDF5:file_name:subdataset
> So it has little use to put the path before the HDF5:. I'm not sure if
> GDAL accepts the path before the file_name. Running the command in the
> same folder should be a safe thing. The output file might go to another
> folder.
Update:
If you run gdalinfo on /path/file_name, you see how the path should be
incorporated inside the quotation marks of the file_name.
HTH,
André Joost
