[gdal-dev] Problem with HDF5 CSK files and .hdr files generated by ENVI
vf victor.fomin.1 at gmail.com
Mon Sep 15 01:44:54 PDT 2014
Dear GDAL developers,
I constate that GDAL (e.g. gdalinfo) fails to open correctly CSK hdf5 files
which have been read before by ENVI software (and .hdr file is generated
near .h5 source file). In this case GDAL uses driver "ENVI/ENVI .hdr
Labelled" instead of HDF5 if the file is not present. Suppression of the
generated .hdr file can fix the problem. Do you think that it is the only
solution ?
Cheers,
Victor
View this message in context: http://osgeo-org.1560.x6.nabble.com/Problem-with-HDF5-CSK-files-and-hdr-files-generated-by-ENVI-tp5161812.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
