[gdal-dev] Problem with HDF5 CSK files and .hdr files generated by ENVI
victor fomin victor.fomin.1 at gmail.com
Mon Sep 15 05:57:11 PDT 2014
Even,
Thank you for the suggestion to skip the driver, it is ok for me.
Concerning other files generated by ENVI, I am not sure how it is working,
but I have the only .hdr file after simple opening the CSK imagery.
Here is the content of the .hdr file :
ENVI
description = {
  COSMO SkyMed # 3 Prod Type: Level 1A Single-look Complex Sland Acquisition
  Mode:ENHANCED SPOTLIGHT Pol: Vertical Tx/Vertical Rx}
samples = 19124
lines   = 14378
bands   = 2
header offset = 0
file type = ENVI Standard
data type = 2
interleave = bsq
sensor type = COSMO-SkyMed
byte order = 0
read procedures = {envi_cosmo_read_spatial, envi_cosmo_read_spectral}
subset procedure = envi_cosmo_read_scroll
wavelength units = Unknown
band names = {
 Real-SCS_U-ENHANCED SPOTLIGHT-VV, Imaginary-SCS_U-ENHANCED SPOTLIGHT-VV}
cosmo info = {
 /S01/SBI,
 CSKS3_SCS_U_S2_19_VV_RD_SF_20140905173604_20140905173612_qlk_S01_00, none,
 none, /S01/SBI,
 CSKS3_SCS_U_S2_19_VV_RD_SF_20140905173604_20140905173612_qlk_S01_01, none,
 none}
Victor
On Mon, Sep 15, 2014 at 2:48 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Selon vf <victor.fomin.1 at gmail.com>:
> > Dear GDAL developers,
> > I constate that GDAL (e.g. gdalinfo) fails to open correctly CSK hdf5
> files
> > which have been read before by ENVI software (and .hdr file is generated
> > near .h5 source file). In this case GDAL uses driver "ENVI/ENVI .hdr
> > Labelled" instead of HDF5 if the file is not present. Suppression of the
> > generated .hdr file can fix the problem. Do you think that it is the only
> > solution ?
> Victor,
> You can define GDAL_SKIP=ENVI as environment variable as well to avoid the
> ENVI
> driver to be used at all.
> We could/should probably register the ENVI driver in last, so to be sure
> it is
> used only after all other drivers have been tried.
> Could you paste the content of the .hdr file ? It is a bit strange that
> such a
> file is generated without a BIL/BIP/BIQ image file that matches it (isn't
> there
> any other file next to the .hdr and .h5 file that would have been
> generated by
> ENVI?). There are perhaps some keywords in that .hdr file that would show
> it
> should be ignored.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140915/73a1aabb/attachment.html>
