[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to transform, unable to compute output bounds.
Andre Joost andre+joost at nurfuerspam.de
Mon Sep 15 07:39:06 PDT 2014
Am 15.09.2014 04:22, schrieb Love:
> Thanks andre, will try this as soon as I can and will give you a update.
> I just want to ask if will it be possible to batch process my hdf files and
> gdalwarp everything if I'm going to specify the -te of each files?
I am not sure if the -te coordinates follow a certain pattern. It should
be possible to read the metadata information with gdalinfo, and extract
the coordinate information with a python script that can build the
gdalwarp command from it. But I am not a python expert.
HTH,
André Joost
