[gdal-dev] ERROR 1: Too many points (440 out of 441) failed to transform, unable to compute output bounds.
Andre Joost andre+joost at nurfuerspam.de
Wed Sep 17 12:45:52 PDT 2014
Am 17.09.2014 04:59, schrieb Love:
> Hi,
> Thanks! But it is workig only for some while for some hdf's, error still
> appears. I assigned one uniform target extent for all the files since this
> was what I specified before I downloaded the files from the oceancolor nasa.
The extent of the hdf file(s) is different than the rectangular extent
you ordered. You have to run gdalinfo on each hdf file to get the
information.
Look out for something like:
   geospatial_lat_max=24.78230858
   geospatial_lat_min=5.343300343
   geospatial_lat_units=degrees_north
   geospatial_lon_max=139.3295746
   geospatial_lon_min=126.3987579
   geospatial_lon_units=degrees_east
HTH,
André Joost
