[gdal-dev] Interpolation when using the WMS format
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri Sep 26 09:14:02 PDT 2014
On 09/19/2014 01:50 PM, Peter Hopfgartner wrote:
> On 09/18/2014 10:30 PM, Even Rouault wrote:
>> Le jeudi 18 septembre 2014 22:23:06, Peter Hopfgartner a écrit :
>>> Salut Evan,
>>> thanks for you recipe. Unfortunately, what I am really interested in
>>> is to
>>> use this from MapServer. Could you give me a pointer in the source
>>> where
>>> the resampling takes place?
>> In gcore/rasterio.cpp : GDALRasterBand::IRasterIO(). I must warn you
>> : quite
>> tricky code
>> But perhaps you don't need code change. In MapServer did you try to
>> define
>> PROCESSING "RESAMPLE=BILINEAR" ?
>>> Thanks,
>>> Peter
>>> Am 18.09.2014 um 22:11 schrieb Even Rouault
>>> <even.rouault at spatialys.com>:
>>>> Le jeudi 18 septembre 2014 17:40:11, Peter Hopfgartner a écrit :
>>>>> Hi, everybody
>>>>> we are using the GDAL WMS driver for getting maps from a public WMTS
>>>>> service, http://www.basemap.at. Anyway, the resulting image does not
>>>>> look smooth. In particular, I would guess that the the image was
>>>>> scaled
>>>>> with something like a nearest neighbor algorithm.
>>>>> So my question is simply, if I can switch the interpolation method in
>>>>> some place.
>>>>> The XML file, taken from
>>>>> http://gisforge.wordpress.com/2012/11/06/basemap-at-wmts-layer-in-qgis/,
>>>>> is:
>>>>> <GDAL_WMS>
>>>>>   <Service name="TMS">
>>>>> <ServerUrl>http://maps.wien.gv.at/basemap/geolandbasemap/normal/google38
>>>>> 57/ ${z}/${y}/${x}.jpeg</ServerUrl> </Service>
>>>>>   <DataWindow>
>>>>>      <UpperLeftX>-20037508.34</UpperLeftX>
>>>>>    <UpperLeftY>20037508.34</UpperLeftY>
>>>>>    <LowerRightX>20037508.34</LowerRightX>
>>>>>    <LowerRightY>-20037508.34</LowerRightY>
>>>>>    <TileLevel>18</TileLevel>
>>>>>    <TileCountX>1</TileCountX>
>>>>>    <TileCountY>1</TileCountY>
>>>>>    <YOrigin>top</YOrigin>
>>>>>     </DataWindow>
>>>>>   <Projection>EPSG:3857</Projection>
>>>>>   <BlockSizeX>256</BlockSizeX>
>>>>>   <BlockSizeY>256</BlockSizeY>
>>>>>   <BandsCount>3</BandsCount>
>>>>>   <Cache />
>>>>> </GDAL_WMS>
>>>>> The command is:
>>>>> gdal_translate -srcwin 35500000 23500000 100000 100000 -of JPEG
>>>>> -outsize
>>>> Peter,
>>>> Resampling done by gdal_translate is nearest neighbour, so not always
>>>> that great.
>>>> What you can do is select an outsize that is compatible with the
>>>> source
>>>> overviews. In TMS, the ratio between sucessive overviews work with
>>>> factor
>>>> of 2, so you should select an outsize of 10000 / 2^N. The closest is
>>>> 10000 / 256 = 390.625 -> 391
>>>> So
>>>> gdal_translate -srcwin 35500000 23500000 100000 100000 -outsize
>>>> 391 391 basemap_at.xml tmp.tif
>>>> and then:
>>>> gdalwarp tmp.tif tmp2.tif -r lanczos -ts 250 250 (you can try
>>>> different
>>>> resampling kernel)
>>>> gdal_translate tmp2.tif basemap_at.jpg -of JPEG
>>>> Best regards,
>>>> Even
> I've tried to simulate the result of different algorithms to further
> investigate the idea of having a configurable resampling step. The
> original tile is 256 x 256 pixels and I've rescaled it to rescale it
> to 200x200 using Gimp.
> The original tile was taken from
> http://maps.wien.gv.at/basemap/geolandbasemap/normal/google3857/8/89/137.jpg,
> a copy is stored at
> https://dl.dropboxusercontent.com/u/4935329/resampling_tests/137.jpg.
> Results
> no interpolation, (nearest neighbor?):
> https://dl.dropboxusercontent.com/u/4935329/resampling_tests/137.resampled_to_200.px-noint.png
> bilinear:
> https://dl.dropboxusercontent.com/u/4935329/resampling_tests/137.resampled_to_200.px-linear.png
> bicubic:
> https://dl.dropboxusercontent.com/u/4935329/resampling_tests/137.resampled_to_200.px-cubic.png
> lanczos:
> https://dl.dropboxusercontent.com/u/4935329/resampling_tests/137.resampled_to_200.px-lanczos.png
> I'd say that the quality of the resampling respects the obove order,
> with lanczos being the best.
> Regards,
> Peter
I finally took the time to have a better look at this.
The attached patch is only for our special case, where data arrives in 8
bit bands  and is certainly far from being decent (I've written my last
C++ code approx. 15 years ago). Anyway, the image quality seems indeed
to improve sensibly.
I used the current SVN version as a base for the development.
Applying the patch I get from
https://dl.dropboxusercontent.com/u/4935329/resampling_tests/basemap.2000x2000-quasiorig.jpg
to this
https://dl.dropboxusercontent.com/u/4935329/resampling_tests/basemap.2000x2000.bilinear.jpg
Anyway, the execution time approximatly doubles (on my 2011 notebook it
passes from  ~ 1.8 s to ~ 3.4 s), which in our case is not really an
issue, but probaly for almost everybody else.
The command line is, starting from the compilation dir:
apps/gdal_translate -srcwin 35555000 23538000 2500 2500 -of JPEG
-outsize 2000 2000 basemap.xml basemap.2000x2000.bilinear.jpg .
Any comment is highly appreciated.
Regards and a nice weekend,
Peter
Peter Hopfgartner
R3 GIS
web  : http://www.r3-gis.com
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20140926/8a648293/attachment.bin>
