[gdal-dev] Migrate to GDAL v2 or not?
Even Rouault even.rouault at spatialys.com
Mon Sep 29 12:00:30 PDT 2014
Paul,
It is difficult to answer on your behalf. If you need new features of GDAL 2,
then it is pretty obvious. Otherwise it depends on if you are confortable with
using a "non vetted" development version (but whose quality you can assess by
running the autotest suite), because you want to do progressive adoption (it
is not excluded that there will be extra interface changes before GDAL 2), or
want to stick with something with a more official label. But we definitely need
early adopters to make it a memorable release.
Best regards,
Even
> We, at the MapWinGIS project, have been using GDAL for years and since last
> year we're using Tamas his pre-build binaries.
> We're now in the middle of upgrading from Visual Studio 2008 to Visual
> Studio 2013 and wonder if this is also a good moment to upgrade from GDAl
> v1.11 to GDAL v2.
> We already recompiled using GDAL v2 and it seems we have only a few issues
> which seems to be easily fixed.
> We won't release a new version of MapWinGIS within a few months, probably
> around X-Mas.
> What is recommended?
> Thanks,
> Paul
> *Paul Meems *
> Release manager, configuration manager
> and forum moderator of MapWindow GIS.
> www.mapwindow.org
> Owner of MapWindow.nl - Support for
> Dutch speaking users.
> www.mapwindow.nl
> *The English presentations of the MapWindow GIS Conference 2014 are online.
> <http://www.slideshare.net/mapwindow>*
http://www.spatialys.com
