[gdal-dev] gdal_translate and PostGIS
Martin Landa landa.martin at gmail.com
Fri Apr 3 02:41:01 PDT 2015
Hi Even,
2015-04-03 11:37 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> As the error message suggests, no, not at the time with the PostGISRaster
> driver which basically only supports creation of a new raster through
> duplicatin an existing postgisraster table thanks to SQL copy mechanisms.
> You have to use raster2pgsql provided with PostGIS for what you want to do.
thanks for confirmation, Martin
Martin Landa
http://geo.fsv.cvut.cz/gwiki/Landa
http://gismentors.cz/mentors/landa
