[gdal-dev] RFC 57: 64-bit bucket counts for histograms
Daniel Morissette dmorissette at mapgears.com
Wed Apr 8 07:10:30 PDT 2015
On 2015-04-08 10:05 AM, Even Rouault wrote:
> Daniel,
>> No comment on the actual change which sounds fine to me.
>> However, could we add a "Version: ..." field to the header of RFCs to
>> make it easier to track down the version to which a RFC applies? I saw
>> that you indicate the version in the status field after a RFC has been
>> implemented, but while it's in draft and during the discussion phase
>> there is no indication of the target version.
> Sure, added
Thanks. That will help. FYI I added a missing [[BR]] in the header.
Daniel Morissette
T: +1 418-696-5056 #201
http://www.mapgears.com/
Provider of Professional MapServer Support since 2000
