[gdal-dev] gdalwarp 'singular matrix' error on AVHRR L1B, but not when executed in GRASS console
Arghesti casperhui668 at gmail.com
Wed Apr 8 15:46:00 PDT 2015
Hi GDAL-Dev,
For my research, I need to use gdalwarp to rectify AVHRR L1B HRPT imagery
(Band 4). I am using the following command to do so, via bash script on
Linux:
/gdalwarp -tps inputfile.SOMEEXT outputfile.tif/
However, I get the following error messages:
/error: inv(): matrix appears to be singular
matrixInvert(): error occured.
  There is a problem to invert the interpolation matrix
  There is a problem to invert the interpolation matrix.
Creating output file that is -2147483648P x 11177L.
ERROR 1: Attempt to create -2147483648x11177 dataset is illegal,sizes must
be larger than zero.
Strangely, the same command works nicely when I execute it under a GRASS
(after initializing the GRASS GUI, selecting the database directory,
location and mapset, and then) using the console on Windows 7. What am I
missing here?
Very much appreciate your help on this issue, thanks in advance.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdalwarp-singular-matrix-error-on-AVHRR-L1B-but-not-when-executed-in-GRASS-console-tp5200513.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
