[gdal-dev] Writing interior rings is not working
Even Rouault even.rouault at spatialys.com
Fri Apr 10 09:23:18 PDT 2015
Le vendredi 10 avril 2015 17:37:38, Heiko Thiel a écrit :
> Hello,
> I currently trying to save Polygons in a ShapeFile with Gdal 1.11.2. It
> works so far - except interior rings are not stored. Anyone any idea?
> My Code:
> #include <ogrsf_frmts.h>
> #include <iostream>
> #include <vector>
> #include <cassert>
> int main(int argc, char *argv[])
>      OGRRegisterAll();
>      OGRSFDriver *poDriver =
> OGRSFDriverRegistrar::GetRegistrar()->GetDriverByName("ESRI Shapefile");
>      if (poDriver == nullptr)
>          std::cout << "ESRI Shapefile driver not available." << std::endl;
>          return 0;
>      OGRDataSource *poDS = poDriver->CreateDataSource("gdaltest.shp",
> nullptr);
>      if (poDS == nullptr)
>          std::cout << "Creation of output file failed." << std::endl;
>          return 0;
>      OGRLayer *poLayer = poDS->CreateLayer("polygons", nullptr,
> wkbPolygon, nullptr);
>      if (poLayer == nullptr)
>          std::cout << "Layer creation failed." << std::endl;
>          OGRDataSource::DestroyDataSource(poDS);
>          return 0;
>      //write 1 polygon with with 1 exterior and 2 exterior rings
>      OGRFeature *poFeature =
> OGRFeature::CreateFeature(poLayer->GetLayerDefn());
>      OGRPolygon polygon;
>      auto outerRing = std::vector<std::pair<int, int>>({ { 0, 0 }, { 0,
> 5 }, { 5, 5 }, { 5, 0 } });
>      OGRLinearRing ring;
>      for (auto &p : outerRing)
>          OGRPoint pt;
>          pt.setX(p.first);
>          pt.setY(p.second);
>          ring.addPoint(&pt);
>      polygon.addRing(&ring);
>      auto innerRingBase = std::vector<std::pair<int, int>>({ { 1, 1 }, {
> 1, 2 }, { 2, 2 }, { 2, 1 } });
>      //auto innerRingBase = std::vector<std::pair<int, int>>({ { 2, 1 },
> { 2, 2 }, { 1, 2 }, { 1, 1 } }); //reverse order don't work too
>      const int innerRingOffsetX = 2;
>      for (int i = 0; i < 2; i++)
>          OGRLinearRing innerRing;
>          for (auto &p : innerRingBase)
>              OGRPoint pt;
>              pt.setX(p.first + i*innerRingOffsetX);
>              pt.setY(p.second);
>              ring.addPoint(&pt);
==> Should be innerRing.addPoint(&pt) (took me sometime to realize that...)
>          polygon.addRing(&innerRing);
>      assert(polygon.getNumInteriorRings() == 2); //this don't throw, so
> gdal detected interior rings
>      polygon.closeRings();
>      poFeature->SetGeometry(&polygon);
>      if (poLayer->CreateFeature(poFeature) != OGRERR_NONE)
>          std::cout << "Failed to create feature in shapefile." <<
> std::endl; }
>      OGRFeature::DestroyFeature(poFeature);
>      return 0;
> Regards
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
http://www.spatialys.com
