[gdal-dev] GDAL NuGet Package
Tamas Szekeres szekerest at gmail.com
Mon Apr 13 02:23:17 PDT 2015
I've planned to provide nuget packages from the binaries provided at
http://www.gisinternals.com/ long ago, but I had no time to include this
support so far.
The corresponding ticket can be found here:
https://github.com/gisinternals/buildsystem/issues/9
The key features of the packaging should be:
1. Support multiple Visual Studio versions.
2. Support the selection of x86/x64.
3. Support release versions as well as and daily built updates.
4. Packaging should fit into the automated build process (should be done
using command line tools).
Any help would be appreciated have this setup realized.
Best regards,
Tamas
2015-04-13 10:54 GMT+02:00 drp33t <peet.whittaker at gmail.com>:
> Hi,
> I am wondering there are any plans to update the version of the GDAL
> package
> in NuGet? Currently the stable release is at version 1.9 (released
> 2012-12-20) and there is also a pre-release alpha for 1.10 (last updated
> 2014-01-08).
> It would be very beneficial for my work if either 1.10 or 1.11 were
> available through NuGet. I am willing to help update / maintain the NuGet
> packages if needed.
> Regards,
> Peet Whittaker
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-GDAL-NuGet-Package-tp5201018.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20150413/a5efdbb2/attachment.html>
