[gdal-dev] Copy meta data from one JP2 to another JP2 C++
Even Rouault even.rouault at spatialys.com
Wed Apr 15 13:06:37 PDT 2015
Le mercredi 15 avril 2015 21:46:26, Dr. Joshua Jackson a écrit :
> I’m looking for a good solution to copy the image meta data from one JP2 to
> another JP2 in C++.  I have a folder full of 4096x4096 JPEG2000 images
> that I am processing with OpenCV.  On some of them I create a copy of the
> image and do some manipulations to.  As expected the new image file is
> missing all the metadata.
> I have tried using CreateCopy() with the OpenJPEG library; and while this
> does work it takes a really long time per image ~40sec.  (My image
> manipulations take only ~10sec).
> Is there some way to use the GetGDALDataSet() on the source file and then
> call SetMetaData() on the destination file for each meta data item?  How
> would one iterate through the metadata items?
The "metadata" you're talking about are more the georeferencing info, right ?
(In GDAL "metadata" is about all other metadata, excluding the georeferencing)
If you use trunk, you could likely try the new USE_SRC_CODESTREAM=YES creation
open of the jp2openjpeg driver
Something like:
gdal_translate your_jp2_without_georef.jp2 out.jp2 -co  USE_SRC_CODESTREAM=YES
-a_srs EPSG:4326 -a_ullr  -96.9653320  32.4645996  -96.9598389 32.4591064
The SetGeoTransform() and SetProjection() API also do something similar
internally, so you could also do :
gdal_edit.py your_jp2_without_georef.jp2 -a_srs EPSG:4326 -a_ullr  -96.9653320
or more conveniently:
gdalcopyproj.py middle_mask.jp2 out.jp2
(http://svn.osgeo.org/gdal/trunk/gdal/swig/python/samples/gdalcopyproj.py)
Even
> Here is a sample GDALInfo printout for a source image:
> Driver: JP2OpenJPEG/JPEG-2000 driver based on OpenJPEG library
> Files: middle_mask.jp2
> Size is 4096, 4096
> Coordinate System is:
> GEOGCS["WGS 84",
>     DATUM["WGS_1984",
>         SPHEROID["WGS 84",6378137,298.257223563,
>             AUTHORITY["EPSG","7030"]],
>         AUTHORITY["EPSG","6326"]],
>     PRIMEM["Greenwich",0],
>     UNIT["degree",0.0174532925199433],
>     AUTHORITY["EPSG","4326"]]
> Origin = (-96.965332031250000,32.464599609375000)
> Pixel Size = (0.000001341104507,-0.000001341104507)
> Image Structure Metadata:
>   INTERLEAVE=PIXEL
> Corner Coordinates:
> Upper Left  ( -96.9653320,  32.4645996) ( 96d57'55.20"W, 32d27'52.56"N)
> Lower Left  ( -96.9653320,  32.4591064) ( 96d57'55.20"W, 32d27'32.78"N)
> Upper Right ( -96.9598389,  32.4645996) ( 96d57'35.42"W, 32d27'52.56"N)
> Lower Right ( -96.9598389,  32.4591064) ( 96d57'35.42"W, 32d27'32.78"N)
> Center      ( -96.9625854,  32.4618530) ( 96d57'45.31"W, 32d27'42.67"N)
> Band 1 Block=1024x1024 Type=Byte, ColorInterp=Red
>   Overviews: 2048x2048, 1024x1024, 512x512, 256x256
>   Overviews: arbitrary
> Band 2 Block=1024x1024 Type=Byte, ColorInterp=Green
> Band 3 Block=1024x1024 Type=Byte, ColorInterp=Blue
> Joshua Jackson, PhD
> Senior ResearchEngineer
>  (800) 604-1822 Ext. 5109 <tel:8006041822,5109>   (256) 648-5109
> <tel:2566485109> josh at nside.io <mailto:josh at nside.io>   www.nSide.io
>  <http://www.nside.io/> 4031 Parkway Dr, Suite B, Florence, AL 35630
>   <http://www.linkedin.com/company/nside/>  <http://twitter.com/nSide__Out>
http://www.spatialys.com
