[gdal-dev] OGR style feature
Luca Delucchi lucadeluge at gmail.com
Fri Apr 17 01:52:52 PDT 2015
On 17 April 2015 at 10:33, Even Rouault <even.rouault at spatialys.com> wrote:
> Luca,
Hi Even,
> it is documented in http://gdal.org/frmt_pdf.html that id is only supported on
> SYMBOL for PDF export, but not on PEN and BRUSH.
Sorry, I read PDF document some time ago and I forgot it, I should check again
> For dashed line, you can use the p/pattern attribute instead.
yes
> For non-solid polygon fill, this would have to be implemented.
I opened this ticket [0], how complicate is this enhancement?
[0] http://trac.osgeo.org/gdal/ticket/5927
> Best regards,
> Even
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
