[gdal-dev] create GeospatialPDF using Python
Luca Delucchi lucadeluge at gmail.com
Fri Apr 17 05:44:19 PDT 2015
On 17 April 2015 at 13:27, Even Rouault <even.rouault at spatialys.com> wrote:
> Le vendredi 17 avril 2015 13:11:15, Luca Delucchi a écrit :
>> On 13 April 2015 at 13:25, Luca Delucchi <lucadeluge at gmail.com> wrote:
>> > Hi all,
>> Hi devs,
>> some updates
>> > For vector it seems quite simple, just writing a new vector and insert
>> > all features but I'm not able to create it, my code [0] is not
>> > returning any error but I cannot find the output file
>> Now I'm able but I'm still not able to read it with GDAL, my example
>> is here [2],
> The link doesn't work.
sorry, http://geodati.fmach.it/gfoss_geodata/prova.pdf
>> maybe some Creation Options is missing?
>> Also If I'm using gdal_translate after that I'm not able to read with
>> gdalinfo
>> gdal_translate -of PDF ../STEM/data/OFD/060140_ravina_OFD.tif my.pdf
>> gdalinfo my.pdf
>> ERROR 4: `my.pdf' not recognised as a supported file format.
> Can the file be opened in a PDF reader ? If so, check that your GDAL is built
> against libpoppler or libpodofo. That's required for the reading side.
Yes the PDF reader can open the file, my GDAL version should be build
against libpoppler and libpodofo
Poppler support:           yes
Podofo support:            yes
> The style is attached to each feature.
ok
>> What is the suggested way to create GeospatialPDF with raster and
>> styled vector together?
> gdal_translate (or CreateCopy) with the OGR_DATASOURCE creation option that
> points to a vector file.
ok
> Did you have a look at Jukka's excellent tutorial ? (the link is at the bottom
> of http://gdal.org/frmt_pdf.html):
> http://latuviitta.org/documents/Geospatial_PDF_maps_from_OSM_with_GDAL.pdf
yes, but I hoped to find another way without use VRT
Thanks for the support
> Even
ciao
Luca
http://gis.cri.fmach.it/delucchi/
www.lucadelu.org
