[gdal-dev] compilation error (trunk)
Even Rouault even.rouault at spatialys.com
Sat Apr 18 13:26:50 PDT 2015
Le samedi 18 avril 2015 12:20:42, Martin Landa a écrit :
> Hi,
> I have problem to compile GDAL trunk on my PC, any idea what could be
> wrong?
> gdalwarpkernel.cpp: In function 'CPLErr GWKOpenCLCase(GDALWarpKernel*)':
> gdalwarpkernel.cpp:3802:1: error: jump to label 'free_warper'
> [-fpermissive] free_warper:
> gdalwarpkernel.cpp:3597:22: error:   from here [-fpermissive]
>                  goto free_warper;
I've just fixed it.
You can't do:
goto some_label;
int foo = 0;
some_label:
But the following is valid (well, compiles):
goto some_label;
int foo;
foo = 0;
some_label:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=55772 quotes the rule from the
C++ standard.
http://www.spatialys.com
